The Right Duct Size - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 11:50 AM   #1
the right duct size
Im going to be installing a goodman 90+ furance in my basement it's going to be a 66,000 output furance. I have 4 rooms down there with a total of 1500 sq. ft. I wanted to know what the right size trunck off the furance would be and return. How long for both and length and width. Ill be running 6 inch take offs from all the truncks to each location. thanks for the help.
eng-399 is offline   Reply With Quote
Old 12-15-2011, 11:57 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
There's a formula for that, though only HVAC people would know that.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-15-2011, 03:17 PM   #3
Rewards Points: 640
That'd be the manual J and manual D and not just HVAC people know it, you can buy the workbooks and figure it out yourself.... I know I just tried that myself
BlueBSH is offline   Reply With Quote
Old 12-15-2011, 06:12 PM   #4
24x10 inches for both supply and return are typical for that size furnace (assuming it was correctly sized), you need much more then one 6 inch to each room though, one 10 inch to each room would do it or a couple of 8's.
bungalow_steve is offline   Reply With Quote
Old 12-15-2011, 06:58 PM   #5
An old Tradesmen
Rewards Points: 6,072
66,000 BTU output for a little 1500 sq ft basement? Very over sized furnace.
Old 12-15-2011, 07:58 PM   #6
How would you know it is oversized without doing a "heat loss" calculation on this home?
Been there myself
Hube is offline   Reply With Quote
Old 12-15-2011, 11:52 PM   #7
Question
duct size help
Thanks for the help I do work in the field but on high pressure boilers and roof top units, make up air units ect... Im a building engineer holding a cfc card like you guys. im just looking for some help here to save a few bucks.... from fellow trade guys... but for my home Im not sure trunck size right off the furance each room would have seveal runs going into it and returns in each room instead of 1 or 2 large returns but you guys think 66,000 is over sized for that space. one room is 31 by 17, 2nd is 10 by 16, 3rd is 31 by24 a full bath and some other space im closing off
Old 12-16-2011, 05:23 AM   #8
An old Tradesmen
Yep, over sized.
The ceiling has no heat loss, since the floor above it is heated. The floor/slab has 50 to 55 degree ground under it, so only a little heat loss, same with all walls below grade.
Basements don't take much to hat them.
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
What size duct i need lenexx miaisis1 HVAC 5 07-04-2010 11:12 AM
adding duct work and outlet jjrbus HVAC 17 05-30-2010 03:13 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 07:29 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 10:38 AM
