Old 08-16-2012, 05:07 PM   #1
Unhappy
Riello oil burner won't start sometimes
I have a Riello oil burner and last winter it intermittently did not automatically start. When I hit the reset button it kicks in fine. It DOES work fine about 85% of the time, but it certainly is annoying when you need hot water and you have to wait 15 minutes for it to heat up. What could be the problem, and could I fix it myself? Thanks
katalina is offline   Reply With Quote
Old 08-16-2012, 08:13 PM   #2
I am a Riello certified Oil Burner tech - retired, Last year, I had the same problem Finally found out all I had to do was tighten the circuit board in the burner control. BE careful..just tighten screws snugly and a bit.
Hope that works for you.
Techpappy Gas and oil techie-Toronto
techpappy is offline   Reply With Quote
Tags
burner, reset, riello, start
Air Compressor blowing start capacitors? BBC3 Electrical 9 04-28-2013 12:34 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
burner fails to start seanyd Plumbing 2 02-18-2010 06:21 AM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 10:05 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 02:37 PM
