Rheem White Powder Near Exhaust Vent? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 08:36 PM   #16
Originally Posted by how View Post
The lack of any signs of scorch marks and the fact that the roll out switches (in the picture) have not tripped make backdrafting an unlikely diagnosis. A badly cracked exchanger could help cool down the vent gases but once again neither the PS or the roll out sw have been affected.
I would recommend that the tech check out the exchanger problem possibility
BUT...
If that B vent is only 5" then his furnace vent would have to be half that size which is not possible. It's more likely that he has an oversized vent, with an long lateral run, 30% less btus with the HWT change, all in a cool garage, hense the condensate powder vent production.
Let us know what your tech finds>
Just got home and was able to double check the labels on the vent its a 5 inch vent.
It a Rheem Criterion II 75K BTU
found the specsheet here http://www.rheem.com/documents/rgph-...ication-sheets
mikebau is offline   Reply With Quote
Old 03-22-2012, 09:01 PM   #17
as seen on tv
Rewards Points: 150
Get a tech to run a combustion analyzer on the furnace to help identify the issue. may be underfired or could need a post purge circuit. A good tech will be able to figure it out in no time
qbert is offline   Reply With Quote
Old 03-22-2012, 09:49 PM   #18
You didn't see the staining in the furnace vestibule?
And if you look close he has a B-vent connector.
If a furnace does not vent properly the products of combustion linger and flow out the burner opening and stain the exterior. It won't usually trip the roll out because the fumes are too cool.
hvac5646 is offline   Reply With Quote
Old 03-23-2012, 12:05 AM   #19
how
Rewards Points: 1,104
Hey HVAC5646
Didn't see water staining but it also doesn't look like a unit that was serviced yearly.. I'll look again.
Changed my C- vent -B vent queston after he posted his pictures. The sequences were strange because the op would add later pic's and additions to his posts.
HVAV quote
Spilling flue gases at the burner mouth of an 80% that are too cool to trip the spill switch is beyond my experience. Are you talking talking about fumes that are part way up the vent that reverse after the ID shuts off?
how is online now   Reply With Quote
Old 03-23-2012, 07:37 AM   #20
Yeah....I had three different situation ...bird in the connector....two partially plugged flues....never tripped the roll out. Flames were lazy but stayed inside.
Old 03-29-2012, 06:35 PM   #21
So here is what the guy came out and noticed. Air filters were dirty which I guess caused the heater to cycle more often. Says the heat exchanger has some loose tubes I dont really know what that means.
I have AC on this house and he says the cooling coil is also dirty.
This house was a forclosure that I purchased so I have no idea what the prior state of repairs was.
I assume the heat exchanger will need to be replaced sometime in the future. Where can parts be purchased for this? Now the AC coil he is telling me he needs to drain the AC pull out the coil to clean it. That sounds a little over the top to me.
Old 03-29-2012, 07:35 PM   #22
how
So..
Did he have nothing to say about the precipitate inside the furnace or was he saying that loose exchanger tubes were the cause of it??
Did you see how he determined that you have loose exchanger tubes and a dirty ac coil?
Bathroom Exhaust Vent Daviddasdj General DIY Discussions 22 01-24-2012 02:13 PM
size of exhaust vent for furnace and water heater 56Wesley HVAC 2 11-09-2011 02:24 PM
Exhaust vent on roof handy man88 Roofing/Siding 1 03-09-2010 10:11 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Popcorn ceiling has been removed, white powder on sills? daz59 General DIY Discussions 19 06-26-2007 06:28 AM
