-   -   Rheem Thermostat (http://www.diychatroom.com/f17/rheem-thermostat-4139/)
wvhilbily 09-29-2006 10:15 PM
Rheem Thermostat
Question, one day i noticed that my A/C wasnt working right. Looked at the thermostat and my Aux heat was on. After looking around and messing around I noticed that if i jumped x to w2 the aux heat went out and the a/c began to work again. Went to test the heat and it doesnt work with the jumper on, so I take the jumper off and the heat works but no a/c. Any Ideas what it can be? Thanks for all the help
also as far as i can tell here is my wiring
R-red
w2- white
x- brown
o - orange (not connected)
b- blue
e- black
y- yellow
g- green
dont know if you might need it, but there it is. Thanks again
#CARRIERMAN 10-23-2006 10:29 PM
Hi wvhilbily
If you have already found your answer just trash this. But if you havent let me know and I will walk you through it.
Good luck.
Rusty
