Rheem Seer Rating - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 06:05 PM   #1
rheem seer rating
Hello, I looked at a home w/a rheem ac unit and I can't see any info on the seer rating of the unit. It's a 14 ajm and a rhkl 4 ton unit. I went on the rheem website and found out that the 14 ajm can have up to a 17 seer rating can anybody tell me what this combination would have? Thanks in advance.
jinxed is offline   Reply With Quote
Old 01-03-2012, 06:14 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,102
it is a minimum 14 seer and depending on the specific model and which size and type of evaporator coil they installed may cause it to be higher. if it the furnace/air handler has a ECM NRG saving motor it adds 1 more seer to the package. w/o knowing the coil type you won't know so I would say 14 seer. if you buy the home get the freon level checked etc so it works properly. seer ain't no good if it is missing freon or the condensor is dirty.
The Following 2 Users Say Thank You to yuri For This Useful Post:
ben's plumbing (01-03-2012), harleyrider (01-03-2012)
SEER Rating on '98 Goodman Unit?? Nola_Gal HVAC 7 07-22-2011 11:12 PM
Getting HVAC Bids--Advice,, Brands, things to look for, seer rating size etc. kennykenny HVAC 0 06-14-2011 12:24 PM
SEER Rating 64 ragtop HVAC 1 10-02-2010 12:40 AM
Replacing a condensing unit with a higher SEER rating unit tylanz HVAC 3 06-28-2010 05:44 PM
Whats the SEER rating? integlikewhoa HVAC 1 04-01-2008 12:08 AM
