Rheem RGRA Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 10:09 AM   #1
Rheem RGRA furnace problem
My furnace sometimes works perfectly and other times the gas valve will click a few times and then maybe or maybe not the furnace will light. I thought the gas valve was probably bad but have been told that they seldom go out and it probably is not a bad gas valve. The fan starts and the igniter glows but at times the gas valve just clicks a couple of times.
Any help will be greatly appreciated.
RonNN
RonNN is offline   Reply With Quote
Old 11-10-2011, 04:20 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 384
Actually they do go/stick. Do you have a gas water heater or other gas appliances and do they work properly. If not you may have low gas pressure from the utility co meter and need to call them to check it.
Furnace drain problem jkennedy99 HVAC 22 12-05-2015 05:44 PM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Possible Lennox Furnace ignitor problem Paulg1 HVAC 4 11-26-2010 04:38 PM
