Rheem RGAA 100A Furnace Blower Continues To Short Cycle - HVAC - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 09:39 PM   #1
Rheem RGAA 100A furnace blower continues to short cycle
Furnace blowers turn off after 30 seconds and burners continue for 10 sec. Full flame when on. Replaced motor about 3 years ago. Filter clean. Temperature never attains to desired degree.
Monica Ehmke is offline   Reply With Quote
Old 03-23-2013, 09:59 PM   #2
Replaced thermostat and still had the problem. Removed the filter and blowers have stayed on and furnace is heating up and working properly. Am checking filter types and direction of reinstallation of filter.
Old 03-24-2013, 03:30 PM   #3
Rewards Points: 582
make sure all registers are open..warm air and cold air....sounds like filter issue..if it runs right with filter out ...ben sr
Old 03-24-2013, 04:59 PM   #4
how
Rewards Points: 1,102
Yup, A temp rise test of the furnace and comparing it with what's listed on the furnace rating plate will show you what filter it can take and what filter might harm your furnace. You can Google how to do it.
A static pressure test can also tell you what's what but requires more equipment than just a thermometer..
how is online now   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
ben's plumbing (03-24-2013)
Old 03-24-2013, 07:10 PM   #5
So far, have had to replace a fuse at the switch where the furnace plugs in and purchased very cheap filters. The blower quit working today. Think the filters suffocated the blower and killed it. Will have to replace the motor more than likely. I have an HVAC friend looking at it now. Thanks for all the input.
furnace short cycle kwidzins HVAC 6 10-06-2011 10:08 PM
Furnace short cycling repman55 HVAC 12 01-21-2011 05:41 AM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 04:27 AM
