Rheem RBHC Air Handler - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 07:35 AM   #1
Rheem RBHC air handler
Help! It's cold & my air handler stopped putting out heat.
It doesn't call for heat often but when it does I don't remember the compressor coming
on but got heat. Now the air handler comes on but there's no heat.
Any suggestions? Is there an internal fuse to protect the heat elements?
Also, my thermostat doesn't have an "emergency" position. Thanks!
steverino55 is offline   Reply With Quote
Old 01-04-2012, 09:22 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
DO you have a Heat Pump?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-05-2012, 07:23 AM   #3
No. Just heat coils.
Old 01-05-2012, 06:44 PM   #4
AKA HVACTECHFW
you need to confirm there is a call for heat on the W wire from the stat. Beyond that you will need to check contactors, sequencers, breakers, heat coils.....
IT IS WHAT IT IS
Upgrade old Rheem Split System fredm54 HVAC 7 05-15-2012 02:04 PM
Rheem RBHC 240v ac/heat unit PJMark HVAC 16 02-11-2011 04:19 AM
Rheem rbhc-21j11sfc single stage heat wiring kilosos2 HVAC 0 12-20-2010 06:59 AM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 09:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
