Rheem Raka 037jaz 2.5 Ton Ac / Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 01:28 PM   #1
rheem raka 037jaz 2.5 ton ac / heat
Replaced 2 pole contactor switch compressor and fan will not stop. inside airhandler runs ok and stops also new inside thermostat. anyboby have any advice. The switch i used was from grainger as all other suppliers denied service to me without a license.
Any help greatly appreciated i been at this off and on 2 days
screenman is offline   Reply With Quote
Old 06-28-2011, 04:22 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
please post a picture...of how the contactor is wired. Also, ensure nothing is holding the contactor in while off. With stat off, check for 24v of coil side of contactor.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-28-2011, 07:31 PM   #3
Thank You Tech
I figured out the problem I had some wireing an ac friend hand done and was loose kicking on and off the handler and to show myself humility I wired the y wire to the wrong post oops. Thanks for answering the post tech and if you need some help w any screen work windows patios etc you let me know. That is my expertise built um 40'tall and 100' wide.
well thanks again im out G
No heat (Rheem gas pack) Kilo HVAC 14 10-04-2010 08:03 PM
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 06:32 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Rheem Furnace No Heat, Help jpellett001 HVAC 1 12-10-2007 09:11 AM
