Rheem Powervent Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2007, 01:30 PM   #1
rheem powervent problem
The fan just runs, sometimes the igniter stays on , other times not. If I remove the tube from the vacc switch , wait and reconnect then the gas flows . Is the vacc switch bad? thanks
ron2368 is offline   Reply With Quote
Old 01-27-2007, 08:01 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi ron2368
Sorry I haven't answered right away, I am getting ready to start a new carrer that is eating up most of my time. It sounds like to me you have a furnace with a two or three light board. Something has gone bad in the board from what I can tell from your post. Both of these boards are quite reliable, I would say to have your funace serviced and the board replaced. Maintenance is a key factor in the problems with any furnace or air conditioner.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 01-27-2007, 09:19 PM   #3
Thanks. I jumped the vacc and it makes no difference, but the ignition control box keeps making a clicking sound and then the ignitor will go off, so I am figuring the problem is in the box. Thank you for your help. I can fiddle with it to keep us in hot water till Monday then I will call .
furnace problem captjack HVAC 8 11-23-2007 12:15 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
