Rheem Package No Heat. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 11:16 AM   #1
Rheem Package No heat.
Hello Guys . Thanks again. I have a thermostat calling. with No pilot. Its a Mdl. RR(GG or GF)-05N24JKR. It has a funny little but heavy fan where an inducer fan might go. But this fan is out in the open not enclosed. and has no vacume diaphram hose lead comming of of it. Its metal bladed. and frozen solid. I dont see the correlation with the pilot problem. Am i likely to have a dual issue on this> and what is this fan for, please?
curtis19 is offline   Reply With Quote
Old 02-06-2012, 11:34 AM   #2
HVAC Tech/ Browns Fan
Can you take a pic of what you are talking about?
Tator1076 is offline   Reply With Quote
Old 02-06-2012, 11:54 AM   #3
Rheem Package.No heat.
Forgive me. I looked up this fan on the internet and it is an inducer motor.DM628. Still a newbie. but at this point, can you tell me if the inducer fan would disallow the pilot to come on.? i get no pilot. Is this an inducer fan culprit? Thank you.
Old 02-06-2012, 11:56 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Yes, most likley. The inducer needs to prove it can safely exhaust the burnt gas so if it's not working right the ignition sequence via the pressure switch the inducer "proves" through does not start.
Thanks.
Doc Holliday is offline   Reply With Quote
rheem raka 037jaz 2.5 ton ac / heat screenman HVAC 2 06-28-2011 08:31 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 06:38 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Rheem rbhc-21j11sfc single stage heat wiring kilosos2 HVAC 0 12-20-2010 07:59 AM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
