Rheem No 120VAC Igniter Help - HVAC - DIY Chatroom Home Improvement Forum
Old 12-25-2009, 09:29 PM   #1
Benihana's Avatar
Unit: Rheem Criterion II HVAC
Hello. For a while now, our heater does not work. The induction motor starts, but the igniter never glows (like our other Rheem Criterion II does), nor does the gas start flowing. From what I understand (which is limited), this is the general order of proper operation.
1) thermostat sends signal for heat
2) Induction motor starts
3) Pressure switch checks for sufficient pressure
4) Igniter starts about 30 s later (glowing red-orange brightly)
5) Gas lines open
6) Ignition
7) Main fan starts to circulate hot air around house
8) Igniter subsides (leaving only blue glow from gas burning)
Here's what I've done so far:
Checked igniter lines: The line never receives 120 VAC. It remains 0 VAC always.
Checked pressure switch: It is clean, and a continuity test revealed that it does close while the unit is operating.
Checked for broken wires: All lines report 0 ohms resistance, concluded good wiring.
I'm wondering what to do next. I'm left thinking that either the motherboard has gone bad, or that there is another piece to the ignition sequence that I am oblivious to. Is there another part that reports back to the motherboard before the igniter is given the signal to start?
Any suggestions on what to do next is most welcome. As a last resort, we can always call a professional.
Benihana is offline   Reply With Quote
Old 12-25-2009, 09:58 PM   #2
Does your furnace board have a diagnostic light/lights to give you a starting point. Most boards will have a light that will blink a series of blinks to indicate different faults.
SKIP4661 is offline   Reply With Quote
Old 12-28-2009, 02:29 AM   #3
Benihana's Avatar
Sorry for the delay. I checked the board, there are 3 LEDs. 2 green and 1 red. The two green will light steady until the point where the gas should light. When it doesn't light, the entire unit turns off and only one green LED (the topmost) stays on. None of them flash or blink at any point.
I must say though, that after having the unit disconnected for several days, that now the igniter does get the 120VAC and glows bright red-orange. The gas never starts and the entire unit turns off shortly afterwards, but at least now the igniter is getting the juice.
I know that the unit checks for sufficient pressure (a la pressure switch), but are there any other conditions that must be met before the unit starts the gas flowing? Perhaps a temperature sensor for the igniter or some other sensors? Thank you for your help.
Old 12-28-2009, 04:56 AM   #4
It's the board...
hvaclover is offline   Reply With Quote
Old 01-04-2010, 01:01 AM   #5
Benihana's Avatar
Turns out it was indeed the board. We got a new board, popped it in and everything works great. Thanks for all y'alls help.
Old 01-04-2010, 04:39 AM   #6
you alls iz welcome
rheem criterion II bryce HVAC 7 10-31-2009 04:54 PM
Replacing Heat Pump system - Carrier or Rheem? CoolMan74 HVAC 6 06-28-2009 11:13 AM
Rheem water heater gas valve issue tsherv Plumbing 4 05-26-2009 10:38 AM
Goodman 80%, igniter glows no flame diyjohn HVAC 16 11-20-2008 03:47 PM
