Rheem Model Rrka-a024jk06e - HVAC - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 06:55 PM   #1
rheem model rrka-a024jk06e
does anyone know where the high limit switch is on the circuit board
NickGiles is offline   Reply With Quote
Old 10-31-2012, 07:10 PM   #2
Rewards Points: 616
its not.....
carmon is offline   Reply With Quote
Old 10-31-2012, 07:12 PM   #3
Oh ok. If the heat is running upstairs but not downstairs then what is the problem. An HVAC guy said the high limit switch might have tripped given the diagnostic from the light on the circuit board
Old 10-31-2012, 07:38 PM   #4
Rewards Points: 616
you have 2 furnaces and what is the make and model ofthe one not working
Old 10-31-2012, 07:53 PM   #5
its the make and model listed in the name of the thread. rheem model rrka-a024jk06e
Old 10-31-2012, 07:56 PM   #6
Rewards Points: 616
the hi limit will have 2 wires on it above the gas valve usually...... don't sell rheem.... post a picture we will point it out for you...
Old 10-31-2012, 08:13 PM   #7
ok thank you. Ill have to do it tomorrow its dark in east tn where I am not and I don't have a light that shines on where the unit is located.
Old 10-31-2012, 08:24 PM   #8
Rewards Points: 616
very well.... someone will help you .....
Rheem gas furnace RGLG-07NAUER fan won't activate via t-stat Dave_Anderson HVAC 8 08-08-2012 10:53 PM
Rheem Gas Furnace, Info on this model ahenderson HVAC 3 12-23-2011 11:57 AM
Rheem Imperial (1990s model) does not work doku HVAC 2 01-09-2011 02:26 AM
older rheem furnace 1990 model rheem imperial 80 twbeach HVAC 2 12-07-2010 07:06 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
