Rheem LP Furnace Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2013, 08:35 AM   #1
Rheem LP Furnace not working
Rheem Classic 90 plus
Model No. - RGTA 10EZAJS
Serial No. - ej50707f190203287
Hey everybody, new homeowner here. Furnace has worked fine until a few days ago. It starts (Blower motor), but only ignites a flame about 5% of the time. When it does have a flame, the Amber light is blinking on the control board. That only lasts about 5 or 10 seconds until the flame goes out, and it recycles two or three more times (with no flame), then goes into the 1 hr lockout. I have already cleaned the flame sensor ( I think ) and checked the hose and ports on the pressure switch for debris, none found. Our house was built in 02' so it has to be a fairly new furnace. It was converted to LP by a certified HVAC co. I am pretty handy, and the HVAC co. wants $150 just to come out here to diagnose it, which i think is a bit steep. Does anybody know what is going on with this thing? Your help is greatly appreciated. My girlfriend is starting to get a little antsy. Here are some pics.
http://i945.photobucket.com/albums/a...ps8f7a949d.jpg
Thank You!
bobweirisajedi is offline   Reply With Quote
Old 01-10-2013, 12:10 PM   #2
Bob the flashing yellow light means weak flame sense
Old 01-10-2013, 12:12 PM   #3
JJboy's Avatar
Clean the flame sensor. Check the ground.
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 01-10-2013, 12:23 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
Sounds like you are geting spark but no ignition. There is a seperate set of electrodes for the spark which is different than the flame sensor. They are difficult to get at and set and clean properly and if you mess them up or bend them etc then the spark will be weak or in the wrong place etc. I would recommend you get a Pro to check them AND the manifold gas pressure which may be too low causing no ignition also.
Old 01-10-2013, 12:32 PM   #5
Rewards Points: 1,294
how full is your LP tank?
danpik is offline   Reply With Quote
Old 01-10-2013, 01:26 PM   #6
Hvac Pro
yuri's Avatar
My thoughts too. If your tank is below 40% it may not generate enough pressure or the regulator from it may be failing etc.
Tags
furnace , newbie , rheem
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Brand New Concord Furnace Doesn't Work In Cold Weather LeighC HVAC 21 01-07-2013 08:48 PM
Gas Furnace Hiccups hugocraft HVAC 2 12-22-2012 06:50 AM
Rheem RGDG-075AUER gas furnace lights intermittently ge01734 HVAC 5 01-01-2012 05:40 PM
Lennox Furnace not working when very cold bsharitt HVAC 2 02-11-2010 05:58 PM
