Rheem Heat Pump & Honeywell VisionPRO - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 06:25 PM   #1
Honeywell VisionPRO 8000 Model # TH8320U1008
Compressor: Rheem# RPKA-024JAZ
Air Handler: Rheem# RBHA-17J10SFAA
Heat pump is 2 heat/1 cool
Question on setup function menu?
Setup Function-------------------- Set to
0220 (1st stage compressor CPH)------ 3
0230 (2nd stage compressor CPH)------ 3
0240 (1st stage heat CPH) ------------3
0250 (2nd stage heat CPH)------------ 3
0270 (emergency heat CPH)------------3
infoskr is offline   Reply With Quote
Old 11-20-2013, 10:28 AM   #2
Do you have an err 89?
What about the rest of the program parameters?
oldgearhead is offline   Reply With Quote
Old 11-20-2013, 05:08 PM   #3
An old Tradesmen
Rewards Points: 8,168
3 is a good CPH for all of those settings. If fine tuning is needed, you can do so later. Let it run a few days after you make any fine tuning adjustments..
infinity heat pump always on aux heat below 40 degree hirrlinger HVAC 4 07-18-2010 12:51 PM
Heat pump problem, indoor fan blows in heat but not A/C or "on" lngroller HVAC 2 06-03-2009 07:55 AM
Heat Pump czars HVAC 3 02-06-2009 08:49 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Wiring a RobertShaw 9870i to Gas Furnace & Heat Pump jerfer HVAC 11 12-21-2008 09:09 PM
