Rheem Heat Exchanger Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 10:42 PM   #1
I just purchased (12/12/2010) a Rheem RGFE09EZCMS furnace with matching coil and condenser. After I removed the furnace from its cardboard container, I noticed a metallic rattle or jingling noise as I moved the furnace to where it will be installed. So I tapped on the exposed primary heat exchanger tubes with my finger, and determined that the heat exchanger is the source of the sound. It sounds as if a washer or a loose piece of metal is inside the tube or tubes. Also, if I lean the furnace forward, I hear something move and then produce a slight metallic clink when whatever is moving reaches its limit of movement. When I bring the furnace back to level and then tilt it backwards, I hear several metallic clinks as whatever it is moves in the opposite direction and stops. I am hesitant to install the furnace not knowing the source of the sound. I am sure that the vibration of the blower would also cause whatever it is to rattle, since only a slight tap with my finger can cause it. Are there baffles of some sort inside the heat exchanger tubes? I cannot find any diagrams of the heat exchanger with that level of detail. Has anyone encountered this? Thanks.
Vulcanus is offline   Reply With Quote
Opinion: Electric WH w/ Heat Exchanger wiremeup HVAC 29 10-03-2010 02:48 PM
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 06:32 PM
Heat Pump Noise in Heat keepitfrozen HVAC 2 12-26-2009 02:47 PM
Heat Exchanger?? sunsetacres1318 HVAC 6 02-26-2009 10:15 AM
Is there such a thing as a dirty heat exchanger? suthrnreject HVAC 8 01-19-2009 08:23 PM
