Rheem Gas Valve Click But Don't Open The Gas - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 08:31 PM   #1
Rheem Gas valve Click but Don't open the gas
Old Rheem model RRGG-05N30JKR. when start, ignator fires up the pilot and turn it on. Wait for about 20-30 Sec, then Valve Clicks but unfortunately gas doesn't flow and furnace doesn't turning on. Any Idea?
sam_ped is offline   Reply With Quote
Old 11-20-2011, 08:33 PM   #2
Rewards Points: 614
clicking does not mean a lot. measure the voltage to the gas valve..
carmon is offline   Reply With Quote
Old 11-20-2011, 08:49 PM   #3
how
Rewards Points: 1,070
There has to be a proving system to verify that the pilot is lit before the main gas will turn on. Usually a rectifyer in the pilot flame. Does it need to be cleaned with steel wool or replaced?
Is the pilot flame large enough to envelope the sensor?
The next step is seeing if the gas valve is receiving 24 V and not firing up as carmon says..
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
sam_ped (11-22-2011)
Old 11-20-2011, 08:53 PM   #4
Milwaukeetool's Avatar
How to diagnose gas valve problems
This post by Nestor Kelebay will explain gas valves very good
Milwaukeetool is offline   Reply With Quote
The Following User Says Thank You to Milwaukeetool For This Useful Post:
Old 11-22-2011, 05:55 PM   #5
Thank you guys. I have 24V on valve. Induce fan is working fine and pilot is on.
Old 11-22-2011, 06:58 PM   #6
HVAC Tech/Owner
Rewards Points: 604
Supply valve open?
Technow is offline   Reply With Quote
Old 11-22-2011, 08:22 PM   #7
Definitely LOL
Old 11-22-2011, 08:38 PM   #8
HVAC Tech/Owner
Rewards Points: 604
Originally Posted by sam_ped View Post
Definitely LOL
Don't LOL , been to two houses this month....one fully shut...the other closed enough to lower the gas pressure but the furnace still worked-found that during maintenance checking gas pressures.
The Following User Says Thank You to Technow For This Useful Post:
Old 11-22-2011, 08:47 PM   #9
It is open. I know. They use gas stove and the pilot is powerful. I open and close the supply valve myself.
Old 11-22-2011, 08:50 PM   #10
REP
You have to be very percise.There are two solenoid valves on the gas valve.If the pilot does come on and whatever is used to tell the gas valve to open actually tells the valve to open and then you hear the click,well thats a bad gas valve.You cannot repair a gas valve.
so if checking the voltage shows you 24volts after the pilot comes on,you have voltage and no gas= bad gas valve.You shyouldn't have 24v until after the pilot comes on.
REP is offline   Reply With Quote
The Following 2 Users Say Thank You to REP For This Useful Post:
Doc Holliday (11-22-2011), sam_ped (11-22-2011)
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 06:03 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 11:01 PM
Rheem water heater gas valve issue tsherv Plumbing 4 05-26-2009 10:38 AM
