Rheem Gas Furnace Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 10:26 AM   #1
Gas Furnace
I have a Rheem gas furnace model RCCA-10EC that needs the little circuit board that is located on top of the gas valve just under where the thermalcouple fastens. The 5 pins that are attached to the board are broken. I took it apart and went to the parts store. The man told me that it is against the law to take that apart and that I would have to buy a new valve. $235. WOW! I think that the assembly is called the ignition control module. Was the man right about buying a whole new valve or can i just buy the part that I need. Thank you.
looyboy is offline   Reply With Quote
Old 01-24-2010, 10:29 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
DON"T double post or the mods will remove you! Use regular black font.
Old 01-24-2010, 12:06 PM   #3
Sounds like you have a honeywell smart valve. The valve is not field serviceable and must be replaced. The price sounds good, better jump on it.
SKIP4661 is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Leaky air valve on furnace dcam HVAC 0 11-01-2009 06:36 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
