Old 02-07-2008, 04:24 PM   #1
Rheem furnace stopped working
I'm at work so I don't have the model or any part numbers, but wanted to see if anyone had an idea of what my problem might be. My furnace (15-20 years old, central gas heat) suddenly stopped working one day. No pilot light, no sound from blower, and no cycling. Found that power was going into the ignition control module/circuit board but none was going out. So I replaced that and now it cycles. I can hear gas come out, but all it does is click on, then 5 seconds later it clicks off. I can hold a flame under the flame sensor and the top row will light, but the four main tubes don't get ignited and after two seconds the furnace turns off gas and shuts off. The blower also never turns on. I checked all the connections and everything is fine. What can you suggest I do?
kgsolomon1 is offline   Reply With Quote
Old 02-09-2008, 07:51 PM   #2
Here are some pictures:
http://i126.photobucket.com/albums/p...1/DSC01079.jpg
http://i126.photobucket.com/albums/p...1/DSC01077.jpg
http://i126.photobucket.com/albums/p...1/DSC01078.jpg
http://i126.photobucket.com/albums/p...1/DSC01076.jpg
http://i126.photobucket.com/albums/p...1/DSC01075.jpg
Problem with Rheem Criterion Furnace sweetsue777 HVAC 3 03-10-2012 12:13 PM
Rheem RGFD Furnace Flashing 66 LED sneaky_pete HVAC 4 12-28-2007 06:31 AM
Rheem Furnace jsfjets HVAC 2 12-06-2007 08:00 PM
installing new rheem furnace to old a coil rad488 HVAC 1 10-17-2007 09:07 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
