Rheem Furnace No Heat, Help - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2007, 06:10 PM   #1
I have been toying with this issue for about 1 week now. It started as the ignitor would glow and the burners would ignite but only run for about 20 secs, unless i utrned off the furnace power for 2 mins then it would run normally for 1-2 days. Now I have the thermostat calling for heat. the gas is working and so is the air blower cause i get air movement thru the whole house. BUT the ignitor( the piece that turns bright red then the flames ignites from the gas) will not turn red. No matter how many or how long I turn off the power to the furnace for.. Any ideas? If i can fix this myself that would be huge. Thanks
jpellett001 is offline   Reply With Quote
Old 12-10-2007, 10:11 AM   #2
It sounds like you just need to replace the hot surface igniter. You can check to see if you are getting 120 volts to it during a call for heat to confirm it is bad. Make sure you use the same style and model as the old one.
cjett is offline   Reply With Quote
Ducane Furnace - no heat dave_in_waterloo HVAC 4 09-19-2012 10:41 PM
Rheem Furnace jsfjets HVAC 2 12-06-2007 08:00 PM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 01:00 AM
installing new rheem furnace to old a coil rad488 HVAC 1 10-17-2007 09:07 PM
