Rheem Furnace Needs Parts Or Replacement? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 02:23 PM   #1
Rheem Furnace needs parts or replacement?
Hi yesterday I was working under the house went for lunch and when I came back smelled gas. Heard the gas valve open yet there was no flame. Turned off power and the valve shut. Powered up and it operated normally. Had a HVAC guy come out and test stuff told me all the electrical tested out well. So I went and took off some of the sheet metal today to see if there was something else wrong and found that a few of the rods that go over the burners were gone. I am not sure if this is what caused the problem but I know it has to be addressed. I am including a pic. If anyone knows if these are a wear item that can be replaced or is it time for a new furnace. In the picture one rod is protruding out of a holder and the one on the left is gone.
Bob10 is offline   Reply With Quote
Old 01-15-2010, 06:37 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,136
We need some more and better pictures with more light and detail and a wider angle pic with all the burners .
Old 01-15-2010, 07:10 PM   #3
How long did you hear the gas on with no flame? If more then a second or two then you have a serious problem, probably control board.
Question about replacement parts for a Bryant furnace. sparkey HVAC 21 03-15-2011 07:21 PM
Rheem 80% furnace 3rdroofdown HVAC 2 11-23-2009 09:59 AM
mobilehome kerosene furnace replacement Davy83 HVAC 5 11-22-2009 10:35 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
