Rheem Furnace/Air Cond Air Volume Is Very Low - HVAC - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 03:21 PM   #1
Rheem Furnace/Air Cond Air volume is very low
Air volume is very low, fan and heat pumps appear to be ok.
Filter cleaned and removed.
Any ideas/suggestions?
Midasguy is offline   Reply With Quote
Old 09-04-2011, 03:30 PM   #2
JJboy's Avatar
Warm or cold air?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-04-2011, 04:19 PM   #3
Its cool air, low volumn
Its cool air, low volumn,
Old 09-04-2011, 04:25 PM   #4
JJboy's Avatar
You need to check if Evap coil is frozen. Check the copper line.
Old 09-04-2011, 04:28 PM   #5
Where is that?
Old 09-04-2011, 04:49 PM   #6
Copper tube iced up outside of air handler (silver box over furnace)
Old 09-04-2011, 09:49 PM   #7
Turned off 2 hours, problem solved,
thanks for the tip, saved time and bucks.
Old 09-04-2011, 10:02 PM   #8
JJboy's Avatar
Not yet... if freeze again, probably your system is running with low charge of refrigerant.
Old 09-04-2011, 10:41 PM   #9
Can a lay person check that? Any tips? Thanks
Old 09-04-2011, 10:56 PM   #10
JJboy's Avatar
You need tools to do the job. It's better call a pro
Upgrade old Rheem Split System fredm54 HVAC 7 05-15-2012 03:04 PM
Rheem 42VR5040F- Any good? Koop Plumbing 0 02-10-2011 03:57 PM
Rheem vs American Standard - packaged Tucson HVAC 11 07-31-2010 04:29 PM
Rheem Water Heater Questions 1972gs455 HVAC 0 01-15-2010 10:44 PM
Controling volume with cable remote pjm Home Theater 3 03-23-2009 10:52 AM
