Rheem Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 07:48 PM   #1
rheem furnace
i have a rheem furnace that burnt the wireing harness where can i get a new wireing harness. i have a new board the furnace is a ugdg125arjr
zeke63 is offline   Reply With Quote
Old 03-22-2011, 09:32 PM   #2
HVAC / Plumbing
have you taken care of what caused the wires to burn?? If you can't just add onto the wires that are left. You will have to see a rheem dealer in your area & see if they will sell to you
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
zeke63 (03-23-2011)
Old 03-23-2011, 06:35 AM   #3
hillbilly guru
Send a message via Yahoo to hvacguytn615
call eds supply 711 6th ave south nashville tn they sell to the general public.eqipment and refrierant are the only things you will need e.p.a and mech lic for have mod ser #s they can ship it or may have a location near you you have the board is that were the short that took out the wireing started make sure to double check
hvacguytn615 is offline   Reply With Quote
Old 03-23-2011, 08:50 PM   #4
yes
the home owner has a 60 amp fuse box and useing a 30amp fuse on his furnace circuit and may have had a power surge i believe.
Old 03-23-2011, 09:33 PM   #5
HVAC / Plumbing
Really depends on the wire size to the furnace as to what fuse/breaker to use. I run anywhere from a 15 - 20 amp breaker or fuse to the furnace. All depends on what the furnace calls for & wire size used
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Rheem 80% furnace 3rdroofdown HVAC 2 11-23-2009 08:59 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
