Rheem Criterion Lights, But Only Runs For 30 Seconds Max... - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2008, 06:59 PM   #1
Question
Rheem Criterion lights, but only runs for 30 seconds max...
Rheem Criterion blower starts up, runs for about 30 seconds until the HSI starts to glow, it ignites and all is fine for about 30 - 50 seconds. Then, it all shuts down with the exception of the blower.
Now, we had the heat exchange replaced last year b/c it was cracked, and while looking at the pressure switch I noticed something. Where they connected the new HX to the exhaust pipe there is a slight gap at the bottom where the "thermal tape" doesn't quite meet up. It seems to be about one inch long and about an 1/8 -1/16 inch wide.
Would that gap cause the pressure switch problem?
Here is a picture...sorry about the blurriness, but you can hopefully still see the gap.
Thanks all-
Rheem Criterion lights, but only runs for 30 seconds max...-100_2915.jpg   Rheem Criterion lights, but only runs for 30 seconds max...-100_2914.jpg
all4naught is offline   Reply With Quote
Old 12-26-2008, 07:00 PM   #2
Wethead's Avatar
It's time to Hire a Professional. This is not something you want to do yourself,
Need Help With Your Pump?►WeT HeaD Pump Repair ► Watch Me On YouTube: Pump Repair TV
Wethead is offline   Reply With Quote
Old 12-26-2008, 07:36 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,800
That is on the downstream of the fan and should be sealed properly so no flue gases enter the house. Won't cause your problem. Rheems have had quite a few pressure switch failure problems on some of the mid efficiency units. You may want to get a pro to check it.
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Problem with Rheem Criterion Furnace sweetsue777 HVAC 3 03-10-2012 11:13 AM
Cold water runs for a few seconds and then stops. . . ineedhelp Plumbing 3 07-07-2008 01:08 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
furnace cycles, runs for 45-60 seconds shuts down and recycles again ronsmoneypit HVAC 4 02-03-2008 01:46 PM
