Rheem Criterion II Won't Fire Up. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-24-2010, 07:08 PM   #16
An old Tradesmen
Rewards Points: 6,914
Sorry. That reply was for another thread.
Check the wires connections at the thermostat.
Old 10-30-2010, 08:39 AM   #17
How do I Jump the R & W? I see "W, RC, B, RC, C, G, O, Y on the board. So I turn the furnace off (at the furnace) then connect which 2 points? And then turn the furnace power on and see if the blower turns on?
Someone mentioned the thermal couple. Im not sure if this unit has one or what it looks like.
clevelandguy is offline   Reply With Quote
Old 10-30-2010, 03:22 PM   #18
An old Tradesmen
Take a small thin piece of wire. And touch the RC and W terminal at the same time.
Old 10-30-2010, 06:26 PM   #19
Found out the t.stat want not working. $25 later my furnace is up and running. Thanks for all the help.
Problem with Rheem Criterion Furnace sweetsue777 HVAC 3 03-10-2012 11:13 AM
Rheem Criterion 2: high fan heat only dyincolor HVAC 2 03-27-2010 09:17 PM
rheem criterion II bryce HVAC 7 10-31-2009 03:54 PM
Need some help with Rheem Criterion II macaluso1 HVAC 4 01-05-2009 09:07 PM
Rheem Criterion lights, but only runs for 30 seconds max... all4naught HVAC 2 12-26-2008 07:36 PM
