Rheem Criterion II Flame On Then Off - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 10:00 AM   #1
Rheem Criterion II Flame on then off
I have a Rheem Criterion II - during the heating cycle the power and the ok green lights are lit, the burners light for a couple seconds then go out. The yellow flame light never comes on. It attempts to light the burners approx. 4 times, then the ok green light flashes.
The flash code is
on-off
pause
on-off
pause
and it continues this flash code.
A service man came over and checked everything and said all sensors check out ok, so he is deducing by process of elimination that its the control board, but wants to charge a lot for replacing it.
Can you give me some insight into the flash code?
Any other insight would be appreciated
homeownerfl is offline   Reply With Quote
Old 01-16-2012, 10:05 AM   #2
remove the flame sensor, sand it off until its brite and shinny again, if that fixes the problem call the company that tried to rip you off and tell them if they don't refund your money you will call the local TV stations and invite them out to due a special on "crooked local heating company".....they will probably hand delver your refund
harleyrider is offline   Reply With Quote
Old 01-16-2012, 11:16 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
the yellow led is for the flame sensor/signal strength which is so weak now that it is dirty that it won't register. nothing crooked about the guy, just dumb and untrained ( could be crooked after all but you can't judge w/o knowing the guy ). not easy to get that sensor out so you may want to call another company. sits under the left burner and looks like this. clean it with clean steel wool and wipe off with a kleenex or #800 wet/dry emory paper.
Old 01-16-2012, 01:19 PM   #4
well, the code it was giving was a flame sensor fault and the OP said that the service tech claimed all sensors were good (obviously they were not) so that leads me to think two things.......the tech was ray Charles, or he was attempting to sell the OP a new board when it was not needed......you don't have to be ray Charles to see that this was an attempt at fraud. fraud in our trade is rampant and it makes it really hard to do business, and to get new business as well. Frauds should be exposed and run off like a rabid dog.
Old 01-16-2012, 05:29 PM   #5
Thanks all very much, I will try your suggestions.
Does anyone have the codes look up table?
At one time the ok green light flashes once, I do remember in the past it use to flash 3 times.
Old 01-16-2012, 05:37 PM   #6
I'm Your Huckleberry
Rewards Points: 2,270
doing some hunting and I found this but can't tell if it's for your Criterion or not. I found it on a discussion concerning a malfunctioning Criterion II and if it is it then
'OK'LED BLINKS TO INDICATE THESE EXTERNAL FAULTS:
(1) BLINK FOLLOWED BY A 2 SEC. PAUSE 1 HOUR LOCKOUT
(2) BLINKS FOLLOWED BY A 2 SEC. PAUSE PRESSURE SWITCH IS OPEN
(3) BLINKS FOLLOWED BY A 2 SEC. PAUSE LIMIT SWITCH IS OPEN
(4) BLINKS FOLLOWED BY A 2 SEC. PAUSE PRESSURE SWITCH CLOSED
A FIFTH CODE IS ADDED ON DELUXE MODELS THAT HAVE TWINNING CAPABILITIES
(5) BLINKS FOLLOWED BY A 2 SEC. PAUSE - FAULT.
http://www.allreds.net/WS2/docs/rhe/rgph-man.pdf
I hope that's it. Good luck.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-16-2012, 05:40 PM   #7
A temperature limit switch opening (3 flashes) would mean your furnace is overheating. Might be time to call in someone to service your system, clean the evaporator and in general make sure you have proper air flow and then check temperature rise.
Thanks.
Old 01-16-2012, 06:00 PM   #8
Thanks Doc.
I did find this online for all interested in troubleshooting a Rheem Criterion II
This one:
http://arnoldservice.com/Troubleshoo...g_Problems.htm
http://arnoldservice.com/furnace%20t...%20charten.JPG
He also has the Control board - cheapest i've seen online:
http://arnoldservice.com/rheem_ruud_control_boards.htm
and the manual is here:
Here are the LED blinking code definitions:
NOTE:
STATIC DISCHARGE CAN DAMAGE INTEGRATED FURNACE CONTROL (IFC)
Old 01-16-2012, 06:13 PM   #9
arnoldservice could pretty much make anyone a service tech.
Thanks.
Old 01-16-2012, 06:16 PM   #10
yup, that's the same manual I posted, must be it.
Thanks.
Old 01-16-2012, 06:21 PM   #11
how
Rewards Points: 1,070
Hey Harley/Yuri
Your right about fraud being rampant in this industry but no more so than incompetance is. Up here its so bad that they make a HVAC tech with a brain and ethics look so good that he will not need to advertise beyond his first year in business.
how is online now   Reply With Quote
Old 01-16-2012, 06:31 PM   #12
Thanks all - after I pulled out the online codes, schematics, manual and troubleshooting flow chart with prices of the replacement parts - the service tech became - lets say - more cautious and less talkative. He knew I knew. Thanks a lot folks....I'll follow up with results later.
Old 01-16-2012, 07:38 PM   #13
Hvac Pro
yuri's Avatar
Originally Posted by how View Post
Hey Harley/Yuri
Don't get me started on incompetence. It is rampant in our business. Unfortunately the business is a dog eat dog affair and the corporate takeover of a lot of the companies with the emphasis on flat rate pricing/ daily profit reports/shareholder BS/margins etc is taking the professionalism out of everything. Freedom 55 or maybe 52 is lookin awful close and good now.
Problem with Rheem Criterion Furnace sweetsue777 HVAC 3 03-10-2012 12:13 PM
Rheem Criterion 2 sensor need popsynth HVAC 1 11-14-2011 04:42 PM
Rheem Criterion II calls for heat and sometimes works. cmkalka HVAC 1 12-08-2010 07:19 PM
Rheem Criterion II won't fire up. clevelandguy HVAC 18 10-30-2010 07:26 PM
Rheem Criterion lights, but only runs for 30 seconds max... all4naught HVAC 2 12-26-2008 08:36 PM
