Rheem Criterion II Calls For Heat And Sometimes Works. - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 09:11 AM   #1
Rheem Criterion II calls for heat and sometimes works.
I have a Rheem Criterion II furnace. Some of the time when the thermostat calls for heat the furnace will work just fine. Other times I will hear the exhaust blower turn on and then the burner turn on and the about 5 seconds later go out. The OK light will then have a flashing about every 4 seconds. When this happens if I turn the thermostat off and then back on or open the door to the electronics and then close it to activate the switch the furnace will start back up again but sometime repeating the problem other times staying on. The filter is clean and the pressure switch is working when I tested it.
cmkalka is offline   Reply With Quote
Old 12-08-2010, 06:19 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 92
Clean the flame sensor with fine emory paper. Sits in front of the left burner and looks like this:
