Rheem Criterion 2 Efficiency - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-01-2012, 09:28 PM   #16
It builds up in little white chunks as you can see from the post. I can squish it very easy.. it's soft
mwpaulson is offline   Reply With Quote
Old 11-01-2012, 10:03 PM   #17
Originally Posted by digitalplumber View Post
Can't help you with the wiring question.
As far as the dust is it soft or hard?
That's ok I started a different thead here so maybe someone can look at it and the new pic and tell me if I'm right in using a 1heat/1cool thermostat that I first got.
Thermostat Wiring O/B & W together?
Old 11-02-2012, 07:15 AM   #18
Rewards Points: 108
Well yes, if you have a single speed furnace and ac, then the one heat and one cool would be all you would need.
A second is needed, like in mine, when you have dual stage furnace. Furnace comes on at say 75% heating capacity (just estimate) then remains there until it determines if additional heat is needed. If no, it heats and thens shuts off normally. If it needs more heating capacity, it goes into 100% or High heat, warms home then shuts down.
or
In a dual stage furnace, if you want it to just blow 100% high all of the time you can connect just the high heat.
digitalplumber is offline   Reply With Quote
Old 11-02-2012, 01:32 PM   #19
or
From what I can tell and reading online specs about the Furnace it seems like it is single speed.
It keeps the house nice a warm at 70F without turning on but a few times throughout the night, fan stays on for like a few mins after the burners go off to blow the rest of the heat out witch is nice, the whole process from start to finish is only like maybe 4-5 mins and last night I only heard it come on a few times. My house is well insulated
Old 11-02-2012, 02:41 PM   #20
Rewards Points: 108
Sounds like you have a great setup!
Old 11-03-2012, 02:03 PM   #21
I hope so, for an older system it seems to work great.
I'm having a different HVAC company come out and do the annual Maintenance, this is what they said they are going to do.
On a gas furnace they clean the burners, check the heat exchanger for any cracks, do a complete inspection on the switches/limits and clean those as need of soot etc. Outdoor unit the outdoor coil is checked, refrigerant levels and condensate lines cleared. It generally takes about an hour for the visit.
Price was not bad and they get the best reviews in my area.
The first HVAC guy that replaced the motor and put the filter in just gave me too high of a quote to do the same as this company.
Old 11-03-2012, 02:17 PM   #22
Hvac Pro
yuri's Avatar
Rewards Points: 382
Does that matter? Seems to be fine.
galvanized can be used but is highly frowned on by most inspectors.
The Following User Says Thank You to yuri For This Useful Post:
mwpaulson (11-03-2012)
Old 11-03-2012, 02:20 PM   #23
Oh good, don't want to replace anything if I don't have to.
Old 11-03-2012, 02:23 PM   #24
Hvac Pro
yuri's Avatar
Rewards Points: 382
galvanized is always a pain to seal even when doing water piping so it can be more prone to leaks but nat gas is supplied at .5psi on the supply so I would not worry. in the future use black iron.
Rheem Criterion II Flame on then off homeownerfl HVAC 12 01-16-2012 06:38 PM
Circuit Board for Rheem Criterion II Furnace jmkamk HVAC 2 01-16-2012 08:44 AM
Rheem Criterion II calls for heat and sometimes works. cmkalka HVAC 1 12-08-2010 06:19 PM
Rheem Criterion II won't fire up. clevelandguy HVAC 18 10-30-2010 06:26 PM
Need some help with Rheem Criterion II macaluso1 HVAC 4 01-05-2009 09:07 PM
