Rheem Condenser Fan Motor Constant Run - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-18-2012, 07:02 AM   #16
Rewards Points: 85
I still have not fixed the problem. I cannot get the old fan blade off the old motor. I guess I could hook the motor up to see if that is the problem but I have not got that far yet.
mferguson0414 is offline   Reply With Quote
Old 09-18-2012, 07:36 AM   #17
I'm Your Huckleberry
Rewards Points: 2,270
Remove that square nut that tightens and holds the fan shroud to the motor axle and drop some oil in there. Let that oil do it's thing. WD-40 or any type of household motor or even cooking oil will work but you might have to apply some and then apply some more into that hole and all over that shaft while giving it time to penetrate.
What you don't want to do is smack that shaft, especially the end of it or you'll be needed to cut it to remove the blades.
After oiling it up: with an adjustable wrench grab the shaft (one side at the least will be flat of that shaft, where the square bolt tightens onto) and then twist that fan shroud. It will loosen. Might need to take some sandpaper to the shaft to knock off any rust and whatnot on what you can get to but again, do not smack that shaft at all!
It will come off.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
mferguson0414 (09-18-2012)
Old 09-29-2012, 01:03 PM   #18
Rewards Points: 85
So an update for those that might care.
I sourced a new motor from Granger. The new motor came with its own capacitor. I have it all installed now and the motor does not spin now when the unit is just idle not running the compressor. My only concern now is there is a slight humming noise coming from the motor unless I set the blades in a certain orientation. Any idea of what that could be caused by?
Thank you
Old 09-29-2012, 01:35 PM   #19
An old Tradesmen
Rewards Points: 6,944
Not sure what you mean by certain orientation.
Old 09-29-2012, 02:06 PM   #20
Rewards Points: 85
Let's say that the fan blade is pointed at 3 and 9 and it makes the Humm. If I move the blades to the 4 - 10 position Iddon't hear it. Does that help?
Old 09-29-2012, 05:38 PM   #21
An old Tradesmen
That would generally indicate a problem with the motor itself.
Old 09-29-2012, 11:16 PM   #22
Rewards Points: 85
So my new motor is bad? I thought it was an indicator that something else was wrong with the system.
Old 09-30-2012, 04:36 AM   #23
An old Tradesmen
Sounds like one of the windings has a slight shut in it.
Rheem No 26 vac to the condenser Bill Texas HVAC 1 08-06-2012 01:40 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 07:05 AM
New Rheem Condenser RPQL-024JEZ Problems gxsalas HVAC 13 07-21-2011 07:50 PM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 01:54 PM
rheem new condenser fan motor install help blueaccord19 HVAC 0 04-28-2010 09:06 PM
