Rheem Compressor Or Reversing Valve Problems - HVAC - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By beenthere
Old 11-15-2016, 01:43 PM   #1
Rewards Points: 2
Rheem compressor or reversing valve problems
I have a rheem heatpump I was told that my compressor was bad, but when I talked to a person who works for a hvac company he said most likely my reversing valve was stuck, this past summer the ac went down, that's when I had it checked, now that it's getting cold, if the compressor is bad will there be heat. I was told that I should have heat, but I don't. Can anyone help me find out what the problem is.
thobbs is offline   Reply With Quote
Old 11-15-2016, 01:48 PM   #2
Rewards Points: 7,224
Re: Rheem compressor or reversing valve problems
You'll have heat if your system has electric aux heat installed or a furnace for backup.
It will be very expensive heat if the former.
Best to get this unit fixed before you need heat.
A compressor is bad if it won't start, is shorted to ground or runs but doesn't pump.
A bad reversing valve or metering device can easily be misdiagnosed as a bad compressor. Get this unit checked by someone who's competent; that may be hard to find.
My Backround FIY: I am not in any aspect of the HVAC business now but have formal education + some DIY experience. Theory is not a substitute for experience; neither is "old school" experience an excuse to not understand or practice the theory.
user_12345a is online now   Reply With Quote
Old 11-15-2016, 05:39 PM   #3
An old Tradesmen
Rewards Points: 6,596
Does the outdoor unit run at all?
supers05 likes this.
Shut off valve placement ? Kenneth M Plumbing 5 01-17-2016 08:02 PM
Rheem 90 Plus Furnace - Gas Valve Chatter Mr. Neone HVAC 15 03-31-2015 08:26 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
