Rheem Compressor - HVAC - DIY Chatroom Home Improvement Forum
Old 07-23-2011, 10:43 PM   #1
Rheem compressor
I need step by step instructions on replacing a compressor
chacha1958 is offline   Reply With Quote
Old 07-23-2011, 10:57 PM   #2
JJboy's Avatar
Recover the refrigerant.
Remove connector ( 3 wires )
unwelding 2 copper line
Remove the compressor
Install new compressor
Welding 2 copper line
Reconnect connector
Leak check with N2
Vaccum the system..... 500micron
Recharge the system
Check SH and SC.
That's it
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-24-2011, 12:31 PM   #3
Test motor & capacitor
I had a repair man come by & told me the motor and capacitor are bad on a Rheem RAKA-037Jaz. How can I test both the motor and the capacitor to make sure both are broken?
Old 07-24-2011, 02:25 PM   #4
Rewards Points: 340
if capacitor is bulged on top it's bad. you can get them on e-bay or a local HVAC supply store for $10-20. if you have a multimeter with capacitance capabilities, turn it to this mode (uF) and connect C to HERM or C to FAN (top of capacitor may have 2 or 3 terminals, depending if it is dual run or not). if it reads 0 uF, it is bad.
what motor is bad? the fan motor?
NitroNate is offline   Reply With Quote
Old 07-24-2011, 04:59 PM   #5
An old Tradesmen
Rewards Points: 8,168
Reconnect connector
Leak check with N2
Recharge the system
Check SH and SC.
That's it
Wouldn't turning off the power be something to do also.
Old 07-24-2011, 05:02 PM   #6
JJboy's Avatar
LOL It's in my signature
Old 07-24-2011, 05:07 PM   #7
An old Tradesmen
I know. But how many missed it. LOL
Old 07-24-2011, 05:13 PM   #8
JJboy's Avatar
Old 07-24-2011, 06:06 PM   #9
HvacWiz's Avatar
Rewards Points: 252
How about EPA certification..
HvacWiz is offline   Reply With Quote
Old 07-24-2011, 08:08 PM   #10
fan motor
I was told the fan motor is bad, how can I test it?
Old 07-24-2011, 08:22 PM   #11
30 year tech
hvac122's Avatar
Don't trust your repairman? You would need a meter to check.
hvac122 is offline   Reply With Quote
The Following User Says Thank You to hvac122 For This Useful Post:
Marty S. (07-24-2011)
Old 07-25-2011, 06:10 AM   #12
Rewards Points: 1,216
Replacing a compressor is like replacing an engine on a car leave it to the mechanics it's not really a DIY thing. Cleaning your own unit and minor troubleshooting along with replacing parts is OK but not replacing a compressor.
Need lots of specialized tools.
COLDIRON is offline   Reply With Quote
Help assembling compressor jfhspike Tools 5 03-27-2011 10:07 AM
Rheem AC unit compressor issues Ogazami HVAC 2 11-29-2010 05:54 PM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
