Rheem Classic Series Super Quiet 80 Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 01:30 PM   #1
rheem classic series super quiet 80 problem
when i have the burner door off it runs fine as soon as i replace the door the burners go out and everything else runs fine take the door off goes through the stages to turn the burners back on put door back on and the same thing happens
sean dokken is offline   Reply With Quote
Old 11-20-2011, 02:07 PM   #2
biggles's Avatar
no return air check your filter or hall return grill check the wiring above the blower panel might be pinching a wire... man that was something to read....
The Following User Says Thank You to biggles For This Useful Post:
sean dokken (11-20-2011)
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 05:02 PM
Problem with Rheem Criterion Furnace sweetsue777 HVAC 3 03-10-2012 12:13 PM
Rheem 90 Plus furnace problem utphotoman HVAC 0 12-11-2009 12:01 AM
Rheem Criterion Problem claydough HVAC 3 01-26-2009 02:14 PM
rheem powervent problem ron2368 HVAC 2 01-27-2007 09:19 PM
