Old 07-04-2008, 02:17 PM   #1
Rheem classic 90 plus venting question
Hello, I have a rheem 90 plus furnace, it is vented through the side of the house with the standard pvc piping, my question is this:
I am putting a 3 season porch on the back of the house where the furnace vents, the vent comes out just a few inches below where the bottom of the new roof trusses are, since the original pvc is running horizontal for about 20 feet before it finally comes out of the side of the house, can I run it a few feet more at the same horizontal plain, then put a 90 degree turn in it and then simply run it straight up through the roof ( which will be about 40 inches or so ) and then I can just build a small soffit inside the porch to conceal the pipe? If the answer is yes, I often see where the pipe that exits through the roof on houses then gets a 180 pipe on it so the opening faces the roof again I am assuming so that rain and snow doesnt enter the pipe, would I want to do that as well ?
The furnace is a Rheem classic 90 plus 120,000 btu.
Thank You
Joe
jjconst07 is offline   Reply With Quote
Old 07-04-2008, 04:27 PM   #2
How many elbows are currently on the vent pipe?
(it sounds like you will reach the limit on the vent)
redline is offline   Reply With Quote
Old 07-04-2008, 06:14 PM   #3
I am guessing 4 elbows so far, its all in finished areas now, but when I built the house I remember about where it went, and to do that would take 4.
Flat roof venting question vendejp Roofing 8 07-17-2008 04:45 PM
Venting question. Bcoleman6 Plumbing 7 03-21-2008 04:41 PM
Question about Cigarette moke and AC venting jtnippon HVAC 2 08-28-2007 01:03 AM
Roof venting question Douche Roofing 1 06-29-2006 02:33 AM
venting question any pros? THEBIGPUNN Roofing 3 02-06-2006 09:19 PM
