Rheem Classic 90+ Burnet Flames Out - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 03:44 PM   #16
An old Tradesmen
Rewards Points: 6,112
Its a flame sensor.
Or in its basic of basic terms.
Its just a piece of metal.
Thats it, a piece of metal. I can use a piece of brazing rod in its place if I want to.
Flame Rectification. Is what you are measuring.
You shouldn't be measuring 3.4" manifold when it lights off.
Old 02-25-2009, 03:46 PM   #17
An old Tradesmen
An over loaded neutral somewhere else in the house has screwed up more then one furnace already.
PS: The V is PWM
Old 02-25-2009, 03:51 PM   #18
An old Tradesmen
Here, read a little about flame rectification.
Flame Rectification
Old 02-25-2009, 04:36 PM   #19
RedNecker's Avatar
BeenThere; That is also my pickup truck license plate number BEN THERE. On the front, I have a vanity plate "DONE THAT"
Thank you, it goes to show an old dog of over 70 can learn new tricks. When I seen a new concept, I try to learn about it.
I read about the flame rectification you posted. Very interesting. It was completely new to me. It explains many of the problems I have.
Here is a good explanation also.
http://robinsofer.com/Johnstone_Supply.html
In effect the flame rod is a half wave rectifier & sends half wave DC pulses back to the controller. That is probably why I measured 480mVDC or .48 VDC at the sensor rod.
That answers why the flame can stay on for 1 second or 6 seconds & go out. The response time of the flame diode is .8 second. The flame can blow away from the sensor rod for a second & the flame goes out.
I will try bending the flame rod into a different part of the flame in the next couple of days. It may need a good steady hot spot.
Do you know the range & amplitude of the proper PWM of the "V" signal?
RedNecker is offline   Reply With Quote
Old 02-25-2009, 05:18 PM   #20
An old Tradesmen
I have it somewhere, but, not sure where off hand.
Old 02-25-2009, 05:24 PM   #21
Rewards Points: 292
Originally Posted by RedNecker View Post
What about the "V" modulating signal? Is it pulse-width? If it is what range & level is it?
If you see an 'H', your getting the V signal.
veesubotee is offline   Reply With Quote
Old 02-25-2009, 05:35 PM   #22
Hvac Pro
yuri's Avatar
Rewards Points: 1,120
PS: The V is PWM
Thats news to me. Can you or an electrician explain it to me/us.
Old 02-25-2009, 06:22 PM   #23
An old Tradesmen
See your PM.
Old 02-26-2009, 06:01 PM   #24
RedNecker's Avatar
I bent the old flame rod after the 90 degree bend into a slight "S".
Installed it & the furnace start up & the burner stayed lit.
Maybe I hit a hot spot with no flame flicker.
If it works all night, that was the fix.
Flame diode, damn, what will they think of next.
I have been out of the computer & electronic market for about 10 years.
Maybe now I can get on with the complete furnace calibration.
Thanks for the point in the right direction.
Red
Old 02-26-2009, 06:15 PM   #25
Some idiot at FT. Smith screwed up the spark gap? Well, no offense but that kinda stuff happens when you go DIY.
Any competent tech would have caught that. All the electronic training and hvac training won't got you thru the day alone.
You just gotta have enough experience to go the distance.
Glad you worked it out.
hvaclover is offline   Reply With Quote
Old 02-27-2009, 03:15 PM   #26
RedNecker's Avatar
What should the AC & DC voltage from flame sensor to ground be?
My old meter said 7 VAC & .48 VDC.
I got a new digital meter & it said 117 VAC no flame , 107 VAC with flame & 30 VDC peak.
Does that sound about right?
HVAClover: "Some idiot at FT. Smith screwed up the spark gap?"
What should the spark gap measure be in inches or what-ever ?
Old 02-27-2009, 04:35 PM   #27
It's something a trained eye would have caught.
Beenthere was talking about manifold press should not be 3.4"wc at start.
I am done with this thread. I think you are just pranking this forum. You keep asking questions in such a way that makes me suspicious.
If you other guys got a gut feeling on this one I would advise you do the same.
Old 02-27-2009, 04:43 PM   #28
RedNecker's Avatar
You seem to be great on Put-Downs, but not so great on actual help. You have never actually answered a direct question.
Red
The Following User Says Thank You to RedNecker For This Useful Post:
newtech (03-06-2012)
Old 02-27-2009, 04:53 PM   #29
Red
I was just listening to you and letting Been do all the answering. He knows your equipment better than anyone here. I refer you back to the fact that you seem to know a lot but the questions you ask contradict that knowledge you possess.
But all I said I was just quitting your thread Why does that upset you unless you are POed about losing part of your audience.?
Any one who was nonplussed would just blow it off with out comment. You act like a comedian who had somebody walk out half way thru his schtick.
Old 02-27-2009, 09:32 PM   #30
An old Tradesmen
Installation instructions will have the acceptable readings for it listed.
Rheem IIBC Fan Speed Switch Settings budkocher HVAC 2 11-28-2012 06:33 PM
Rheem classic 90 plus venting question jjconst07 HVAC 2 07-04-2008 06:14 PM
installing new rheem furnace to old a coil rad488 HVAC 1 10-17-2007 09:07 PM
Rheem RXCH-A14 drain pan needed johnd393 HVAC 10 05-14-2007 01:58 PM
