Rheem Centurion Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 05:35 PM   #1
Question
Rheem Centurion gas furnace
I have been having an issue with my furnace the past few days and am in need of some help/advice/direction as to the possible cause of the problem. First, the problem is inconsistent and happens at different times during the day. Also it appears that it is happening randomly without any action taken by me. The furnace will cut on and run through its normal start up process and proceed to begin to blow hot air, but it will only run for approximately 1-2 minutes, then it will shut off long before it gets anywhere close to matching the temperature that the thermostat is set to. I tried increasing the temp on the thermostat by a few degrees, only to have the same thing happen. (Thermostat is on an interior wall in the hallway).
Again, this happens intermittently (sometimes it will happen twice before it runs through complete cycle, other times the heat wont run normally for 4 or 5 hours causing the house to get quite cold). In case it has an impact on a solution, the hot water heater also runs on natural gas and has been working perfect.
Any suggestions/help are greatly appreciated.
Thanks!
Rfolmar19 is offline   Reply With Quote
Old 01-30-2012, 05:43 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
http://arnoldservice.com/furnace_flame_sensors.htm
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-30-2012, 06:04 PM   #3
how
Rewards Points: 1,070
Do you have a blinking diagnostic led light on your furnace? Look for it through the door grills or an inspection port. If its on a board behind a door with a door switch then tape that switch shut so that the next time the furnace locks out, you can open that door and record the flashing sequence without losing it when the power goes off.
Let us know what you find?
how is offline   Reply With Quote
Old 01-31-2012, 03:35 PM   #4
No blinking diagnostic led lights that i could find. Did clean the flame sensor, it had vry little dirt on it and I am still having the same issue with my thanks again
Old 01-31-2012, 04:36 PM   #5
An old Tradesmen
Rewards Points: 6,124
Check flue pipe. Also check pressure switch hoses for moisture and dirt at the ports.
rHEEM FURNACE GAS SHUTS OFF AFTER 3 SECONDS TERRY38121 HVAC 13 01-24-2014 07:28 PM
Rheem Gas Furnace, Info on this model ahenderson HVAC 3 12-23-2011 11:57 AM
Rheem furnace blower motor does not come on automaticall wrightti HVAC 5 11-12-2008 06:29 PM
Rheem RGFD Furnace Flashing 66 LED sneaky_pete HVAC 4 12-28-2007 06:31 AM
Rheem Furnace No Heat, Help jpellett001 HVAC 1 12-10-2007 10:11 AM
