Old 12-04-2010, 12:27 PM   #1
Rheem Burner Issue
I worked as a HVAC Installer for 5 yrs in the late 90s so i have fair skills in Service end. My moms 3 ton gaspack burner is only lighting on first two burners and then shuttin off ..
Toolman35 is offline   Reply With Quote
Old 12-04-2010, 12:39 PM   #2
Professional
Rheem Burner Issue
remove burners and clean all the crossovers
hvactech126 is offline   Reply With Quote
Old 12-04-2010, 12:58 PM   #3
Hvac Pro
Rheem Burner Issue
Check the orifices on the manifold when the burners are removed. Spiders/bugs can get in them and block them.
Old 12-04-2010, 12:59 PM   #4
Smile
Rheem Burner Issue
Thank you that is what i thought but needed a bit of feedback i work 7days on 7off as Wastewater Plant Operator and wont be off till Monday to work on it ... She has GAs logs for heat until i get there.
Old 12-04-2010, 01:11 PM   #5
Hvac Pro
Rheem Burner Issue
Couple of those cheap $25 ceramic heaters from HDepot are always good to have for emergencies.
Rheem hot water heater - pilot / burner not staying lit? CZSteve Plumbing 25 01-17-2013 02:30 PM
Rheem Classic 90 Burner not kicking in sperez HVAC 1 01-30-2010 09:49 PM
Goodman Furnace Burner issue hansim4 HVAC 5 10-08-2009 08:26 PM
Rheem water heater gas valve issue tsherv Plumbing 4 05-26-2009 10:38 AM
Rheem Furnace issue JeffHogan HVAC 9 12-28-2008 09:39 PM
