Old 07-08-2011, 09:37 AM   #1
Rheem ac new contactor wiring
Hi, I am trying to find out how to connect the low voltage wires on the New Protech contactor I am installing it on a Rheem RAKA 037JAZ AC unit. Protech Contactor model number 42-102851-01. I can send photo's of old and new contactors to your private email if necessary. My email address is jwerba1@att.net. Please notice the pictures I downloaded of the old, and New Contactor are a few posts down.
Many Thanks, Werbs
Werbs is offline   Reply With Quote
Old 07-08-2011, 11:25 AM   #2
Post your pics here; people will help for free as that is the purpose of the site.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Werbs (07-08-2011)
Old 07-08-2011, 11:54 AM   #3
Professional
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
Werbs (07-08-2011)
Old 07-08-2011, 12:04 PM   #4
Thanks for the reply. I need to find out how to post pictures on this site. I am not used to using URL in order to post pic's.
Werbs
Old 07-08-2011, 12:33 PM   #5
For how to post a picture:
How to attach a photo to a post
Werbs (07-08-2011)
Old 07-08-2011, 02:12 PM   #6
I hope this works. I need to know how to transfer (where to put) the Brown, and Yellow Wire mounted on the side of the old Contactor, and the Orange wire that is mounted on one of the Top Spades of the Old contactor on the New Style Contactor. I assume they go on the A1, and the A2 spades, but I don't know what color goes where if so!!!
Thanks, Jim
Rheem ac new contactor wiring-img_0209.jpg   Rheem ac new contactor wiring-img_0226.jpg   Rheem ac new contactor wiring-img_0258.jpg   Rheem ac new contactor wiring-img_0260.jpg   Rheem ac new contactor wiring-img_0261.jpg
Old 07-08-2011, 06:28 PM   #7
Professional
use the picture I posted! Yes, 24V wires either one to either side go on the side of the new contactor
IT IS WHAT IT IS
Werbs (07-08-2011)
Old 07-08-2011, 07:03 PM   #8
Thanks! Does the orange one that is mounted on the spade on top go to one of the sides also?
Old 07-08-2011, 07:08 PM   #9
JJboy's Avatar
Brown and Yellow goes to A1 and A2
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Werbs (07-08-2011)
Old 07-08-2011, 07:16 PM   #10
Hvac Pro
the THIN yellow and brown wires are the 24 v low voltage for the coil of the contactor new and old and it does not matter which terminals they go to on the new one as long as one is on each side of it. NO other wires go there. The rest of it is just labelling and replacing the wires as they are on the old one to the same terminals on the new one. Make ABSOLUTELY sure both the high voltage wires coming into the old contactor have no voltage from them to ground. I have seen double pole disconnect switches that were faulty and only disconnected one leg/hot source when turned off. Other one can be live and kill you. Make a note of that JJ.
The Following 2 Users Say Thank You to yuri For This Useful Post:
JJboy (07-08-2011), Werbs (07-08-2011)
Old 07-08-2011, 07:36 PM   #11
I am sorry to ask again, but where(what side) does the thin orange wire that is mounted to the top of the old contactor
go??
Thanks Again, Jim
Old 07-08-2011, 07:47 PM   #12
JJboy's Avatar
Doesn't matter the side just follow the old contactor.
L1, L2 means line and T1, T2 load
Werbs (07-08-2011)
Old 07-08-2011, 07:59 PM   #13
Hvac Pro
the thin orange wire that goes from the "top" of the contactor to the capacitor goes to T3. you better make darn certain ALL those wire connections are very tight to the new contactor. may need new stakon connectors. if even a bit loose they heat up, turn black, get looser and drop the voltage to the compressor and motor and cause damage. sounds like you need a Pro or electrician friend to help out. get any of these wrong and the compressor/ motor or capacitor may be permanently damaged or burn out.
The Following User Says Thank You to yuri For This Useful Post:
Werbs (07-08-2011)
Old 07-08-2011, 08:10 PM   #14
Thanks Yuri, The one wire that I couldn't seem to get an answer on is the one that you said goes to T3, and now it makes perfect sense to me.
God Save The Queen!
Old 07-09-2011, 09:24 AM   #15
Hello, if the the thin orange wire that goes from the "Top" of the Old contactor to the capacitor goes to T3 which is a high Voltage terminal how come it isn't a thicker wire?. Is it because it doesn't carry much of a Load? It is seen best in my 2nd photo.
Thanks To All, Werbs
Upgrade old Rheem Split System fredm54 HVAC 7 05-15-2012 03:04 PM
Rheem vs American Standard - packaged Tucson HVAC 11 07-31-2010 04:29 PM
Anybody had any problems with Amana or Rheem? Rasputin Off Topic 1 06-19-2010 01:35 PM
Rheem vs. Amana fajoza45 HVAC 3 02-20-2010 12:35 AM
Rheem Water Heater Questions 1972gs455 HVAC 0 01-15-2010 10:44 PM
