Rheem 80 Plus Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2008, 12:37 PM   #1
My Rheem 80 Plus Furnace from about 1985 is not starting when the thermostat turns system to on.
The part that looks like a solenoid(B) buzzes loudly when switched on. I previously put in a new exhaust fan(E) and vacuum hose when the old squirrel cage rusted out. I have an second identical system so I swapped parts to see if I could diagnose the problem. I tried swapping the board that has (A) and (B) and then the board that has (C) and (D). Neither worked. Anyone have any ideas?
Your suggestions would be greatly appreciated.
Thanks,
Greg
techdesigner is offline   Reply With Quote
Old 10-18-2008, 07:41 PM   #2
You got a volt meter handy? You gotta track down where the power stops: That's where the problem is
hvaclover is offline   Reply With Quote
Old 10-20-2008, 08:50 AM   #3
Yup, start with your transformer and make sure you have power around 24VAC. Next, be sure your draft inducer motor is getting power, exhaust fan as you call it. There's a temp sensor, a high temp safety sensor and heating surface igniter. Whip out your DVM and work from the simplest things to the more complex.
dac122 is offline   Reply With Quote
Old 10-20-2008, 09:10 AM   #4
DVM....lol sounds like the initials of an adult film star.
Tags
furnace , rheem
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 01:32 PM
Inside Fan not working BenH HVAC 20 07-08-2008 06:10 AM
Working with granite... SDeeter19464 Remodeling 5 06-14-2008 05:51 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
Rheem furnace stopped working kgsolomon1 HVAC 1 02-09-2008 06:51 PM
