Old 01-01-2013, 10:17 PM   #1
Reznor XL75 nat gas heater install questions
I've got a hanging heater and am trying to figure out the best way to vent. Can this be vented through the gable wall and then through a chimney pipe up over the roof? The heater is in the front corner of my garage and I don't want a chimney going out the front of the roof if I can avoid it. It has an oval vent, 4" x 5.5". Do I need an adapter or can I squeeze a round pipe over the oval? I have looked for a manual for this unit but have been unsuccessful. Any advice will be appreciated! Thanks
mikec35 is offline   Reply With Quote
Old 01-01-2013, 10:23 PM   #2
you need the manual..... and yes you can vent it through the roof.... follow instructions in manual for venting......
carmon is offline   Reply With Quote
Old 01-01-2013, 10:24 PM   #3
https://www.rezspec.com/index.php?pa...0014&mod_files[currpos]=54
Old 01-01-2013, 10:24 PM   #4
hold on.....just re read your post...what do you mean through a gable wall then up over the roof..... sounds not right .......
Old 01-01-2013, 11:33 PM   #5
I tried their website and could not find the manual. I emailed them today for a copy- hopefully they will send me one. I want to exit the vent horizontally through the side wall then connect to a chimney pipe outside the garage. Thanks
Old 01-02-2013, 10:53 PM   #6
Found the manual, I am going to vent it horizontally through the wall then up over the roof on the outside of the building. It has a 5" oval, do you think it would hurt to downsize the vent to a 4 inch chimney?
Old 01-03-2013, 05:51 AM   #7
An old Tradesmen
If the furnace breech is 5 inch, then code prohibits reducing the size of the chimney to 4".
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Tankless Water Heater Install - Completed Reilley Plumbing 0 02-08-2009 09:37 PM
What switch to install between panel and 220 volt heater Rogers Guitar Electrical 4 01-21-2009 07:08 PM
240V Electric Heater install - 3 wire vs. 4 wire? dhgarage Electrical 7 12-12-2008 11:49 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
