Reznor XL-400-3 Question - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 04:28 PM   #1
Rewards Points: 31
Hello,
I have a 400,000 BTU input Reznor heater I want to install in my 2400 sq ft shop. I have 12' high block walls and a low slope wood roof. The roof is raised [framed] 4' above the front block wall and sitting on the wall in back. I want to put the heater in the back corner of the building. The heater is approx. 3'1" tall, so I have about 8'11" to work with. I needed to know how far below the wood deck the heater should be placed? Also, my flue pipe is 10" oval and will exit very near the back of the building through the roof. Will this cause any extra problems with snow/ice buildup/backup? The rear of the roof has been a problem area in the past. It is such a large roof that when the snow melts it moves to the rear of the roof and sits there causing premature failure.
Any comments/suggestions/opinions are greatly appreciated!
Thanks,
nadorp is offline   Reply With Quote
Old 10-25-2012, 05:45 PM   #2
An old Tradesmen
Rewards Points: 6,116
Sounds like the roof isn't insulated. Which can cause the snow/ice damn problem you have.
You'll need to find the install instructions to know how much clearance you need above it to combustibles.
400,000 sounds a bit large for 2400 sq ft. guessing little to no insulation.
Old 10-25-2012, 08:23 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
The clearances should be listed on the heater. Usually on the back by the rating plate.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-25-2012, 08:52 PM   #4
REP
As mentioned ,you will need to know tolerances.You can call Reznor for informatin.you will also need the oval to round connector for the flue.You will need "B" vent to go through the roof.you will need at least 2 foot above the roof and you will need 10 feet clearance from the top of the flue pipe to any wall or other flat surface in all dsirections.
As others have said.you might want to insulate,Spray foam is quick and easy.
REP is offline   Reply With Quote
Old 10-25-2012, 10:39 PM   #5
Rewards Points: 31
Thanks for the replies.
I have no insulation, but I also didn't have heat until now. I tried contacting Reznor about getting manuals/literature and their response was "Since this model has been discontinued for more than 20 years, manuals are only available to HVAC technicians that are registered users of the Reznor website"
So, I need to figure this out without manuals.
Old 10-25-2012, 10:51 PM   #6
AKA HVACTECHFW
http://www.longviewweb.com/reznor/XL.pdf
Page 2 shows an example of tags that should be on your unit.
FYI, the heat exchangers on those crack often on the front side at the bottom corners of each cell.
IT IS WHAT IT IS
Old 10-26-2012, 11:10 AM   #7
Rewards Points: 31
I'll have to check that out. If it is cracked, can it be fixed? and how much of a problem does it create?
Thanks!
Old 10-26-2012, 04:31 PM   #8
An old Tradesmen
Cracked heat exchangers can't be fixed. they can be replaced. But when its an older furnace, its better to just replace the furnace.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (10-26-2012)
Old 11-04-2015, 01:17 PM   #9
Rewards Points: 31
Well after a 3 year set back with rebuilding my shop and other things I have the furnace hanging. I decided to switch over to propane and have a question on venting. Can I still run my 10" vent up through the roof or do I need to use a power venter?
Old 11-04-2015, 04:03 PM   #10
An old Tradesmen
Shouldn't need a power venter.
nadorp (11-05-2015)
Old 11-04-2015, 05:54 PM   #11
Rewards Points: 3,524
Is this unit configured for LP, or natural gas? Has the heat exchanger been checked out?
roughneck is online now   Reply With Quote
The Following User Says Thank You to roughneck For This Useful Post:
supers05 (11-04-2015)
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
