Reznor UDAP 125 Won't Light - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 10:19 PM   #1
Unhappy
Reznor UDAP 125 won't light
got a Reznor udap 125 that was converted to lp for free, hung it, plumbed it, wired it....it works. now that it is cooler out 19 at night 40 during the day (heater worked great 2 months ago when we put it in) it won't light.
when you send the call for heat
1 exhaust fan kicks on
2 you hear the ignitor start and run
..no fire
exhaust fan continues to run ignitor starts and runs again and again no fire.
i'm wondering if the lp port is clogged? also on top of the regulator in the unit there is the shut off knob which i can turn to "off" "on" or "c" what is "c"?
stupidcosmoline is offline   Reply With Quote
Old 10-27-2011, 10:51 PM   #2
biggles's Avatar
pressure switch is bouncing the heating call .pressure switch proofs the ID is running and starts the 24Vs to ignite and main gas burner
Old 10-28-2011, 09:12 AM   #3
so where do i go from hear?
Old 10-28-2011, 09:27 AM   #4
biggles's Avatar
see that silver 4" round donut that has 2 wires to it jump it out to see if you get the cycle
Old 10-28-2011, 10:33 AM   #5
there's a 2 1/2" black and gray plastic looks like diaphram with a hose that runs to the exhaust booster with 2 wires
otherwise there is the valve body itself with 2 wires coming in the top but it sure isn't round is that what you are talking about?
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
