Old 12-29-2012, 03:29 PM   #1
Reznor ft75 garage heater wont ignite flashes 3 times
My Reznor ft75 wont fire up.It does not have a pilot light. It has a code that flashes 3 times.I tried jumping that part with no success. I know most of these have reset buttons,but i can not find it. It has been working great for years! Any ideas?
J GLASGO is offline   Reply With Quote
Old 12-29-2012, 03:50 PM   #2
the flashing lights are supposed to be a aproblem in the pressure switch,jumped it and it made no difference.
Old 12-29-2012, 05:21 PM   #3
Any birds nest in venting?
HVACTECH96 is offline   Reply With Quote
Old 12-30-2012, 10:22 AM   #4
HVAC Tech/ Browns Fan
Port on draft motor maybe plug if flute pipe is clear.
Tator1076 is offline   Reply With Quote
Old 12-30-2012, 10:26 AM   #5
An old Tradesmen
No its not suppose to be a problem in the pressure switch. It means there is a problem establishing proper draft through the furnace.
As said earlier, check the flue pipe, pressure hoses and ports for obstructions.
Old 12-30-2012, 10:30 AM   #6
Is the Draft motor even running?
Old 12-30-2012, 01:04 PM   #7
You guys are good! The draft motor is moving very slow,barely actually. So it is not pulling vacuem to close the switch. Now i have to figure out where to get one.Thanks fellas!!
Trane XR90, LED flashes 2 times for error James35 HVAC 48 12-16-2012 12:49 PM
Garage gas heater ronlin HVAC 2 12-05-2011 07:29 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Modine garage heater princeofpain HVAC 1 02-06-2011 03:35 PM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 02:01 PM
