-   -   Reznor ft75 garage heater wont ignite flashes 3 times (http://www.diychatroom.com/f17/reznor-ft75-garage-heater-wont-ignite-flashes-3-times-167703/)
J GLASGO 12-29-2012 02:29 PM
My Reznor ft75 wont fire up.It does not have a pilot light. It has a code that flashes 3 times.I tried jumping that part with no success. I know most of these have reset buttons,but i can not find it. It has been working great for years! Any ideas?
J GLASGO 12-29-2012 02:50 PM
the flashing lights are supposed to be a aproblem in the pressure switch,jumped it and it made no difference.
HVACTECH96 12-29-2012 04:21 PM
Any birds nest in venting?
Tator1076 12-30-2012 09:22 AM
Port on draft motor maybe plug if flute pipe is clear.
beenthere 12-30-2012 09:26 AM
No its not suppose to be a problem in the pressure switch. It means there is a problem establishing proper draft through the furnace.
As said earlier, check the flue pipe, pressure hoses and ports for obstructions.
Tator1076 12-30-2012 09:30 AM
Is the Draft motor even running?
J GLASGO 12-30-2012 12:04 PM
You guys are good! The draft motor is moving very slow,barely actually. So it is not pulling vacuem to close the switch. Now i have to figure out where to get one.Thanks fellas!!:thumbsup:
