Reznor FE 200 Unit Heater Won't Ignite - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 06:51 PM   #1
Reznor FE 200 unit heater won't ignite
I have a Reznor FE 200 gas heater in my garage that has worked fine for many years and now when I turn thermostat on for heat all I get is a click sound and the vent blower motor to run but no ignition.I have changed the thermostat because it was old and not very accurate and I have changed the module and still no ignition.I have about 28 volts at the transformer going to the thermostat.I have an intermittent pilot setup and don't see any spark and even tried to light the pilot with a match but still nothing.I am looking for any help in fixing this problem before I have to call a service tech and spend more money that I could save if it is just something simple.
ed kara is offline   Reply With Quote
Old 11-07-2010, 09:25 PM   #2
HVAC / Plumbing
You should be able to hear the spark . Make sure pilot valve is opening. If pilot valve is opening. try cleaning the pilot
kenmac is offline   Reply With Quote
Old 11-07-2010, 10:17 PM   #3
No spark.
Pilot valve is not opening and the only thing that works is the fan for the vent.
Old 11-08-2010, 07:01 AM   #4
HVAC / Plumbing
You say you have 24v from transformer to t.stat...check for 24 v from t.stat to the module. 24v at ps, limits, etc
Old 11-08-2010, 12:37 PM   #5
I think I found the problem.When I bypass the pressure switch everything runs good.I checked the vent for any obstruction and all looks clear so it looks like I need a new pressure switch.I hope that is all I need.
Old 11-08-2010, 01:24 PM   #6
HVAC / Plumbing
ps may not be the bad. Chect the vent motor where the ps hose connects. those small holes will stop up. preventing suction to close ps
The Following User Says Thank You to kenmac For This Useful Post:
ed kara (11-13-2010)
Old 11-08-2010, 06:29 PM   #7
I will check the holes when I go to the shop tomorrow before I order a new pressure switch.Thank you for helping
Old 11-13-2010, 08:02 PM   #8
I just wanted to let you know that I changed the high pressure switch and everything works good.
Thanks for the help and replying to my post.
Have a good day!
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Glacier on my AC Unit? Where's Al Gore? livinginthepark HVAC 10 07-13-2010 03:59 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
Venting Water Heater near Central Air Unit rchrivera Plumbing 5 03-16-2010 11:03 PM
Gas Hot water heater, burner will not ignite hammerdome Plumbing 8 10-14-2009 05:04 PM
