Reznor F75 Garage Heater Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 03:10 PM   #1
Reznor F75 Garage Heater won't shut off
I have a Reznor F75 garage heater that will not turn off. I replaced the thermostat and I'm thinking that the relay was burnt shut after the earlier thermostat failed. Any suggestions? Is this difficult to fix?
Jim_B is offline   Reply With Quote
Old 02-20-2011, 04:32 PM   #2
fabrk8r
fabrk8r's Avatar
Is it firing? or is it the blower that won't turn off?
Open "high-limit" switch will make the blower run continuous and it won't fire.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 02-20-2011, 07:01 PM   #3
Renzor F75 heater won't stop running.
The heater fires, but just keeps on running.
Old 02-21-2011, 01:39 AM   #4
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
Maybe the wires are touching somewhere. Try disconnecting them from the unit and see if it stops running
unicursalhex is offline   Reply With Quote
Tags
reznor f75 garage furnace
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 08:41 AM
Switch and/or timer for 220v garage heater? vsheetz Electrical 11 12-02-2009 11:37 PM
How to Shut Off Water Heater From Boiler skittlzski HVAC 2 10-23-2008 08:29 AM
$59 "vent free" heater for garage? pcampbell HVAC 2 03-26-2008 03:24 PM
Heater Fan wont shut off!!! :( UpsideDwnCircle HVAC 8 12-26-2007 10:43 PM
