Rewiring Furnace Electrical Circuit - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 02:10 PM   #1
Rewards Points: 640
Rewiring furnace electrical circuit
Alrighty, so the builder did this all wrong.... but wanted to check with you guys before I work up a redo plan...
right now the furnace (Gas, 4 ton blower) runs off a 20 amp circuit... you'd think that'd be a dedicated circuit right?...
well the circuit goes to an electical box, which as 2 outlets on it (15 amp outlets) which they had the gas water heater plugged into (direct power vented ao smith one) then that then branched off to the furnace, first to a on/off disconnect switch then to the actual furnace from there... well then there is another branch from the outlet that for some reason goes to the basement bathroom that connects to the GFCI outlet and lighting...
alright, so I know the Bathroom MUST be taken off the circuit because that should have its own circuit for lighting for one, and a seperate circuit for the outlets... I think that was the NEC code? but the furnace / water heater is what has me bugged...
can I leave this water heater on the furnace line? or do I need to add another circuit for it?
also, my air conditioner has its own 220v 30amp circuit, is this enough protection? it says min ckt ampacity 25.9 max fuse or ckt. bkr. fusible circuit hacr per nec 45... 30 amp is where that wants to be I'd assume?
BlueBSH is offline   Reply With Quote
Old 09-21-2010, 02:18 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
The ventor on the water heater draws a small amount of amps/read the label. Add it to the furnace on startup after a power failure and it could trip the breaker and freeze your pipes. I am sure the electrical code and ins co.wants furnaces on their own circuit. Always been that way where I am.
Old 09-21-2010, 02:26 PM   #3
Rewards Points: 640
all my water heater says for a power raiting is "less then 5 amps"... gota love those specifics.....
Old 09-21-2010, 02:30 PM   #4
Hvac Pro
yuri's Avatar
Startup/inrush current is usually 5x running current. Ever seen a frozen up house. Water meter top bursts like a zit and you need a canoe to get around.
Old 09-21-2010, 02:34 PM   #5
Rewards Points: 640
yeah, probably better to have seperate lines anyways just to be safe even if code around here doesn't require it yet... so 3 new circuits to add..... yay *lol*
2 for bathroom and one for water heater..
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
basic switch from 4-wire? benepperson Electrical 6 08-17-2010 01:41 PM
Insulation around a electrical circuit breaker box terpsing Electrical 4 02-03-2009 04:08 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Furnace Help tuasoi HVAC 2 11-29-2007 01:54 PM
