Rewire Automatic Damper Always Open? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 07:43 AM   #1
I have a automatic Damper that has stripped gears and won't let my boiler turn on. I talked to the guy that installed the boilers years ago and he said he sometimes just rewires them to be always open but didn't tell me how to do it. Does anyone know how they are rewired to trick the boiler into thinking it is always open? The plug is just four wires. Thanks
Troyrb is offline   Reply With Quote
Old 02-02-2014, 07:59 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,728
Ayuh,... Why not replace it, 'n fix it Properly,..??
Bondo is online now   Reply With Quote
Old 02-02-2014, 08:40 AM   #3
Because if it doesn't really make much difference having it there, then why spend the extra $300 for a new one.
Old 02-02-2014, 08:43 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 396
It does make a difference, it prevents your heat and $$ from rising up the chimney 24 hrs/day. Imagine having a 5 or 6" hole in your roof letting air and $$ out. Also makes your home less drafty and more comfy as air is not being sucked in around your doors and windows to replace the air going out the chimney.
The Following User Says Thank You to yuri For This Useful Post:
hvactech126 (02-02-2014)
replacing damper motor in air exchanger chrome HVAC 1 11-12-2013 09:33 PM
Troubleshooting Damper Motors macou HVAC 1 09-14-2013 08:47 AM
Vent damper wont open draft34 HVAC 0 11-01-2011 08:20 AM
To open up the kitchen or not timbo59 Building & Construction 15 04-30-2010 01:17 PM
adding 3rd zone to honeywell trol-a-temp system bhelman HVAC 5 03-03-2010 04:11 PM
