Old 09-25-2012, 05:51 PM   #1
Review of proposed wiring diagram for a new install
Hello all!
I am somewhat new to the world of HVAC and in particular to hot water systems. Nonetheless I have undertaken the conversion of my existing oil boiler to gas. I chose to use a G124x that I was able to source used (gently) and for a very reasonable price to replace my very aged Weil Mclain boiler 68. For reasons that are too complicated to get into in this post, I have elected to use the G124x with a 2107 logamatic control (using OEM 8148E aquastat), on top of an LT200 tank. 3 bell and gosset variable speed circulators for the heating circuits and a single taco 007 for the DHW. Additional, I have procurred a Taco SR503-2 to switch the B&G circulators. I have replaced the motor and wheel on the existing Fields SWG4 powerventer and plan to switch the existing CK63 from the original 120V to 24V for use in a gas application. Minus the original WMO switch and add the GSK-3 spill switch about rounds out the plans.
I have attempted to piece together the process and control wiring from what each manufacturer has for available information and was hoping others might review and advise if this is even close before I get underway with the final steps. I have a licensed electrician working with me, but he is a little weak on the control side of things and was hoping to have something for him to look at. Thankful for any advice or input in advance. Will provide pictures of the install once it is wired. All plumbing, gas, and venting is complete at this time.
Thanks again
Review of proposed wiring diagram for a new install-schematic-layout-boiler.jpg
mcoody is offline   Reply With Quote
Tags
aquastat 8148e, buderus, fields, logamatic, wiring
Correct wiring diagram for 1 story house jdm001 Electrical 63 06-24-2010 05:35 PM
Basement wiring diagram review majesticjess Electrical 18 03-04-2010 02:05 PM
Looking for a HVAC control wiring diagram garya505 HVAC 3 10-09-2009 11:01 PM
wiring diagram question screenporch21 Electrical 10 11-30-2008 09:14 PM
can you review this diagram jheavner Electrical 17 10-12-2008 11:37 PM
