Reversing Valve Cycles - HVAC - DIY Chatroom Home Improvement Forum
Old 07-05-2011, 10:17 PM   #1
Reversing valve cycles
I am having trouble with a 10 year old Amana PTAC unit. It will not control temperature when in the AC mode. It will freeze you out of the room, but won't control. Recently I purchased an external thermostat (Totaline/Venstar T1010), the required wiring harness kit from Amana (PWHK01C) and some thermostat wire. All connections were made per direction from Amana and Totaline. The thermostat works, with one caveat. The reversing valve cycles when no system call (heat or air) is in progress. As soon as the thermostat calls for heat or air the unit works great. As soon as the temperature reaches the setpoint and the unit stops, the reversing valve begins to cycle again. As the name implies, I'm 'outa my league' here. Any thoughts?
Outa my league is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
testing reversing valve wetbar HVAC 2 05-26-2011 08:43 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 11:01 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
