Reversing Valve - HVAC - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 01:51 AM   #1
reversing valve
I have a customer that is popping the inline fuse on the circuit board. It is a Carrier 2.5 ton heatpump. I checked all the wires and found it would not pop the fuse if I unhooked the common going to the t-stat, so I thought it was a bad t-stat. shorted g,r,y,o with t-stat off the wall and popped fuse again. changed common wire going to t-stat and tested by shorting all out again- pop fuse. When I unhook the orange wire every thing work fine except in heat mode, So I went to the outdoor unit, reversing valve read 2.2 ohms, I thought that was low so I put straight to 28V and it just spark. Tested a new valve read 22 ohms. test new valve outside the unit,could hear clicking every time I applied power. So the old one was defiantly bad. Changed valve,test poped the fuse and smoked the t-former. When back tested valve now it is shorted! Im thinking the board must be bad and taking out the valve, right?
Is there a way to change the coil only on the valve? took me 2 hours to change it before.
Thanks for the help.
subcool is offline   Reply With Quote
Old 05-22-2013, 05:41 AM   #2
An old Tradesmen
Rewards Points: 6,540
The coil is generally only held on by a screw. They are easy to replace.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (05-22-2013)
Trane heat pump Tstat and reversing valve jarrdj HVAC 1 02-03-2013 10:38 AM
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 06:36 PM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 01:02 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
